Brief Description: Fabric Tape on Bottom of Upper Right Wing
Installed fabric tape over each of the four rivet stitched ribs on the inside bottom of the wing. Bushed down each tape with glue and then wiped down with a shop towel. Applied a tape to the end rib bottom. Applied a fabric tape to the wing tip by first marking the center of the tape and then applying the center line of the tape along the wing tip. Ironed it in place and then bushed glue over the tape. Wiped away the excess with a shop towel. The remaining ribs are awaiting the supply of rivets to arrive to be completed.
