Brief Description: 250 Degrees Ironing of the Upper Right Wing
On the top fabric of the wing added fabric tape to the two joints. Applied glue over the tape and wiped away the excess with a shop towel. Let the glue dry.
Turned the wing over so the bottom side was up. Completed the attachment of the top fabric to the wing tip by ironing it in place after pulling it tight. Trimmed away the excess material around the wing tip and ironed the edges down.
Set the large iron to about 250 degrees and started ironing the fabric in the center rib on the bottom of the wing. Alternated on each side of the center rib ironed on both sides of each rib. Now again starting in the center ironed between the ribs alternating right and left of center. Turned the wing over and repeated the ironing process on the top of the wing. The next step is to iron the wing at 300 degrees for the next work day.
