Brief Description: Rivet Stitched Bottom of Lower Left Wing
Ironed the bottom fabric at 300 degrees. Applied fiber tape to each rib on the bottom of the wing. Plugged in the soldering iron and set it aside to heat.
Melted each hole on the wing ribs across the bottom of the wing with the soldering iron. Installed a pop rivet in each of the stitch holes. Cut a tape the length of each rib and glued it in place centered over the line of rivets. Put a tape cover over the left end of the wing. Measured the tape for the wing tip leading edge. Set it aside and left for the day.
