Brief Description: Inspection Ports on Bottom Lower Left Wing
Install a tape along the bottom of the leading edge by gluing it down and then wiping the glue from the top of the tape. Glued a tape along the wing tip, aileron cutout and the trailing edge. Glued the ten plastic rings in place where marked on the wing bottom. Left them to dry.
Marked ten circles on scrap fabric to cover the inspection rings. Using pinking shears cut out each of the marked circles. Center the circles over the inspection rings and marked the outside edges. Applied glue inside the marked area and laid a fabric circle over the inspection ring. Added glue to the top of the circle and then wiped away the excess with a shop towel. Repeated the process for the remaining nine rings. End of day.
