Brief Description: Continued Connections For 12V Accessory Plug
Connected the black ground wire to the right side terminal block. Routed the red power wire up over the gas tank and down behind it. Measured the length needed to connect to the battery and cut away the excess wire. Installed two wire labels on the power wire sliding them up to the top of the gas tank. Routed the red wire back down behind the gas tank and across to the main power solenoid. Slid a third wire label onto the wire and then installed a crimp terminal and shrink-tube over the terminal. Attempted to mount the accessory plug power wire onto the master solenoid but was unable to get the nut started. Will try to correct the connection during the next work day.
Mounted the "Passenger Warning" placard on the instrument panel above the accessory plug.
