Brief Description: Moved Top Left Wing to Work Table
Removed the cable clamp from the left side front cable. Prepared to remove the excess cable from the crimp but could not fine the steel plate used to protect the cable from the cutoff wheel. Have to look in the shop or make a new shield.
Also found that the Nicopress sleeves that I have in my supply box are for 1/8 inch cable and not the 3/32 inch cable I need to install for the cross bracing on the center wing struts. I'll have to do some checking and find a supply to complete the cable runs.
Evaluated the location for the addition of a external battery connection in the belly pan of the aircraft. There is space on the left side of the battery to accept the mount for the plug. Marked and cut out a L shaped bracket to be used to mount the plug to the belly pan. Additional work during the next work day will be required to fit the plug to the belly pan.
Moved the top left wing from the wing rack to the work table with the bottom side up. Started evaluating the possible ways to install the AOA signal wire within the wing. The wing root has a bracket where the tubing for the airspeed and static air are mounted. A bracket will need to be fabricated to attach inside the wing near where the wing strut attaches to the wing for the male end of the plug to attach too.
