Brief Description: Install Floor Pans and Rudder Bars
Placed the two right floor pans in place over the mounting tabs and installed an AN3 bolt through the right rudder bar bracket arm, the pan and the tab welded to the frame. Repeated the process for the left rudder bar bracket arm, pan and the tab welded to the frame. Installed the left side rudder bracket and pans the same way. Attached the right side braces to the rudder bracket and secure the ends to the frame tabs through the pan with AN3 bolts. Attach the rudder cross bar to each of the rudder bar assemblies.
