Brief Description: Added Holes for the Volt Meter in the Insturment P
Sanded the blue points with 1000 grit sandpaper on the wheel covers. Applied the final coat of blue paint with the mini roller to all of the blue points. Set the wheel covers aside to dry.
Punched a 2 inch hole in the upper right corner of the instrument panel. Used the drill and round sanding drum to smooth out the slight enlarge the punched hole until the volt meter gage fit through the hole. Next drilled a 3/16 hole at the top left area from the volt meter for the alternator warning light. The third hole punched was a 1 1/8 inch diameter opening for the USB power plug.
Removed the edging tape from the outer wheel cover star points. Care was taken to prevent any paint from pealing up when the masking tape was removed. The area around the points was sanded smooth removing any over painting the occurred. The next round of masking and painting will occur during the next work day.
