Brief Description: Installed Tubes for Pitot and Control Cable Faring
Installed two lengths of 1/4 OD tubing for the pitot and static ports. Used two hose clamps on each tube at the pitot assemble to secure it. Marked the tube that goes to the pitot at the end of the wing.
Glued two aileron control cable faring to the top of the right wing and the bottom of the left wing. Cut a fabric patch to fit over the faring and glued it in place. Ironed the patch over the faring and then applied a coat of glue over the patch. Wiped away the excess glue with a shop towel. Repeated the process for the other wing.
