Brief Description: Control Assembly Modification for Aileron Control
Mounted the 2 inch extension to the aileron control arm and connected the control cables. Tested the control throw and felt that it would work with the cockpit occupied and near full aileron deflection obtained. However another issue came up as the aileron cables now were crossing the cockpit high enough to come in contact with the rudder and tail wheel cables. Consideration is now going to have to be made on alternative routing for the aileron cables.
Another corner brace installed on the lower left wing.
