Brief Description: Sanded and Applied Finish Coat to Cockpit Sides
Used 000 steel wool to smooth the sides of each plywood section. Wiped down with a cloth and check for any ruff areas. Applied the steel wool to any areas needing further attention. Again wiped down the plywood with the cloth.
Applied a coat of varnish to the finished side of each of the plywood sections. Set aside to dry.
