Brief Description: Modification of the Left Throttle Mounting
While testing the right throttle travel it was noted that the aft end of the left throttle plate was flexing a inch or more from the fuselage. This required the additional of a mounting tab. One was cut, drilled and taped and positioned on the fuselage. It was mag welded in place. A 1024 by 1/4 inch screw was used to secure the throttle plate to the tab.
