Brief Description: Installed Anchor Nuts on Bottom of Instrument Pane
Removed the instrument panel assembly from the fuselage. Removed the bottom edge from the instrument panel. Installed a 1032 anchor nut on the left side of the bottom bracket in the last hole using two 3/16 inch pop-rivets. Repeated the process for the last hole on the right side of the lower edge bracket.
