LARRY'S WEB SITE
Date:  8-21-2017
Number of Hours:  1.25
Brief Description:  Mounted Anchor Nuts for Instrument Panel
Mounted the wood side panel on the right side of the fuselage and mounted the instrument panel on the right side. Double checked the alignment of the instrument panel and side tab and drilled a 3/16 inch hole through both. Removed the side panel and mounted a anchor nut in the hole drilled in the side tab. Drilled a pop-rivet hole in the side tab to secure the anchor nut. Installed a pop-rivet in the anchor nut and then drilled the second hole. Installed the second pop-rivet completing the installation of the anchor nut.
Repeated the above processes for left side panel.
Side Tab for Instrument Panel Mount
