Brief Description: Installed Anchor Nuts on Lower Instrument Pannal
Installed anchor nuts across the top of the brace every 4 inches. Started by drilling a 3/16 inch hole and then attaching the anchor nut to the hole using a short 10-32 screw. Positioned the anchor nut's wings parallel to the top edge of the bracket and drilled a hole for the pop rivet. Installed one pop rivet and then drilled the other hole. Installed a pop rivet there to complete one anchor nut installation.
