Brief Description: Mounting Flang for Electric Fuel Pump
Measured and cut a length of 1/2 by 1/8 steel bar to fit at the firewall to support mounting of the electric fuel pump. Hammered a Z shaped on one end and drilled a 1/4 inch hole there. Ground each end smooth and removed burs from the hold. Hung bracket from a wire and painted it black.
