Brief Description: Drilled Holes on Instrument Panel for Cable Mounts
Measured the diameter of the Mixture Control Cable which came out to be 3/4 inch. Drilled the 3/4 inch hole in the bottom flange with half crossing on to the instrument panel. Mounted the Mixture Cable and then measured off on the left side the position for the Primer cable. The Primer cable required a 7/16 inch hole which was drilled in the flange. Measured the Oil Accumulator cable and placed it on the far left side of the flange. To the right of the Oil Accumulator cable a 7/16 inch hole was drilled for the Emergency Fuel Shut Off cable.
