LARRY'S WEB SITE
Date:  1-18-2017
Number of Hours:  3.00
Brief Description:  Mounted Center Wing Struts to Fuselage
Adjusted the wood frame so that the center wing section was 27 inches above the fuselage. Double checked that the fuselage was level. Rechecked the height of the center wing section was 27 inches measured from the center of the top fuselage longeron to the center of the top wing spar. Also set the front spar 5 inches back from the fuselage firewall. Marked each of the wing's vertical struts where they intersect the fuselage longerons at the mounting posts. Cut each of the vertical struts at the marked locations and slid each strut over its mounting post. Drilled each of the vertical struts and mounting posts with a 3/16 inch hole and installed an AN3 bolt in each strut.
