LARRY'S WEB SITE
Date:  2-14-2018
Brief Description:  Left Wing Lift and Drag Cable Rigging
Removed the ferrule from the drag cable on the aft side of the left wing. Shorted the cable by two inches and clamped in place with a cable clamp. Attempted to reconnect the drag cable at the wing fitting but it came up too short. Reset the clamp to shorten the cable by 3/4 inch. Reconnect the drag cable and tighten it to tension. Checked the angle of the aft spar to 3.10 deg and the spacing of the turnbuckle. Tighten the turnbuckle on the lift cable to tension. Checked the angle of the aft spar at 3 deg. As both cables and the turnbuckles were within tolerance crimped both ferrules to complete the cables.
Left Wing Forward Drag Cable
Left Wing Forward Lift Cable
Left Wing Aft Drag Cable
