LARRY'S WEB SITE
Date:  12-6-2017
Brief Description:  Checking Wing Configuration and Bracing
Secured one end of a 3/32 cable to a steel tab using a thimble and crimp. Trimmed the loose cable end close to the crimp. Mounted the tab on the upper end of the strut with a AN3 bolt. Measured the cable across to the bottom of the opposite strut and cut to length. Mounted a tab to lower end of the strut and connected a turnbuckle to the tab with a 3/16 inch pin and cotter key. Mounted a thimble in the other end of the turnbuckle and pulled the 3/32 cable through the thimble. Secured the cable to the turnbuckle with a crimp after pulling the cable hand tight. Repeated the process for the second cable on the opposite strut.
Right Wing Drag Cables
Left Wing Strut Bracing
Left Wing Strut Brace Turnbuckle
