Double check the measurements for each spreader fitting location. Drill a 1/4" hole at each location taking care to position the hole in the top spar pipe and drilled vertically. Select each set of brackets per the plans for each position. Install the AN4 bolt called out in the plans through the bracket(s) required for each position. Tighten each bolt and ensure the threads are showing above the nuts.
