Brief Description: Development of Windshield Mounting Base
Cut a section from a 2 by 6 board that was the width of the windshield. Marked the curvature of the fuselage front cover on the bottom of the board and then marked the curvature of the windshield on the top of the board. Found that the 2 inch width would not work to support the angle of the windscreen required. Found a section of 4 by 4 and cut a length from the end at the same length as the 2 by 6 board. Marked the curvature on one side of the 4 by 4 and cut away the excess material from the top of the board. Marked the curvature of the windscreen on the top of the board. Mounted the board in a vice on an angle which would present the windscreen at a vertical angle when mounted correctly. Attempted to cut a grove with a router on the necessary angle for the windscreen. It was difficult to see to follow the line of the curvature with the router but one pass was completed.
