LARRY'S WEB SITE
Date:  10-15-2019
Number of Hours:  1.10
Brief Description:  Added Plywood Slats to the Turtleback
Installed two 3 by 30 inch by 1/4 inch plywood slats under the aluminum sheet and over the runners on the turtleback next to the seat back. Added a third slat that was 3 by 24 inches long next to the first two under the turtleback. Held each of the slats in place by installing two 1/8 inch pop rivets with washers in each of the slats on the center line. This is to provide reinforcement for the turtleback to support ingress and exit from the aircraft.
