Brief Description: Finished Motor Mounts and Tail Handle
Finished tip welding each of the mounts to the frame checking to ensure good welds. Cleaned up each mount with the grinder with a fine grain wheel.
Measured the handle frame and marked the cut locations. Used the chop saw to remove the excess pipe and ground the ends to mate up with the longeron. Spot welded the handle to the frame and checked that it was square. Completed tig welding the handle to the longeron and cleaned up each weld with a wire bush.
After the welds had cooled painted the handle and the motor mounts with black primer paint.
