Check the level and square of the aft stub on the right side. Spot welded the bottom edge on both sides. Checked the level and square again and adjusted as required. Completed the weld around the stub to the fuselage. Also welded the bottom tab to the underside of the fuselage. Ran out of welding gas. Remove the tank and returned it for a refill.
