Brief Description: Installed Wing Gap Cover and Safety Wired Turnbuck
Removed the left wing stub lower access cover and the three access opening covers. Installed the lower left wing gap cover with six 1032 pan head 3/8 inch metal screws all mounted on the bottom of the wing.
Installed the remaining seven access covers on the fuselage and right wing bottom. Counted up the covers and opening remaining and discovered that I'm one cover short. Ordered some additional covers tonight to finish completing the covers.
Completed wiring eight turnbuckles with safety wire using the single twist method with four to five turns on each end. Will work on the remaining turnbuckles during the next work day.
