Brief Description: Shoulder Support Insert Reinforcements
The foam edges around the plywood shoulder support inserts were beveled.
Shop temperature 24 degC and humidity 60%.
A batch of epoxy was mixed using 128g resin and 48g hardner.
Three ply BID cloth 5" x 5" was wet out then cut into sixteen 1.25" squares. Four squares were applied on top of each of the four plywood shoulder support inserts resulting in 12-ply of BID on each of the four inserts.
A small batch of micro was mixed and applied to the sides of both front seat headrests. Two ply of 10" x 30" BID cloth was wet out and then cut in half and the 5" x 30" pieces were applied to the sides of both headrests. An extra 3 plies of BID was added at the top of both headrests and peel ply was used at the rough edges.
