Brief Description: Shape heat duct transition piece form
Trimmed and sanded the rough edges at the top back side of the seatback/shoulder support.
Sanded a radius on the forward corner of the shoulder brace.
Trimmed and sanded the headrests.
Vacuumed the sanding dust and cleaned up the workshop.
Cut 2 ply of BID cloth to size to cover the shoulder support.
UND cloth was prepared for the 7-ply heat duct reinforcement.
A transition piece (heat duct to engine) was carved out of urethane foam. The piece is 6" long and 1.5" x 1.5" square at the bottom and 1 7/16" diameter at the top. The transition piece was covered with black tape so the foam won't stick to the fiberglass.
