Brief Description: Fabricated wood blocks for clamping longerons
I fabricated 18 wooden blocks to use for clamping the lower longerons down after floxing. I plan to use 18 for each fuselage side. The blocks are 1.5" x 1.5" x 0.75". On each block, I made a 0.5" cut and a 45 deg angle cut to mate with the triangular longerons.
