Cut out trim pieces from an old rudder skin I had. The original pieces that shipped with kit were not big enough to cover the rear skin opening to the back of the rear canopy. Get the pieces to lay out properly took longer than I had anticipated. So I only did one side today. Tomorrow I will work on the right side. Hopefully it will go quicker. I still need to put top row of rivets in side pieces into canopy. Also need to back drill holes from rear bulkhead into trim pieces. That will be where I start tomorrow.
