Brief Description: Painted and mounted landing gear
Painted landing gear with 3 coats of gray epoxy primer paint. After paint dried I mounted gear to fuselage using rubber gaskets and mounting brackets. These are the mounting brackets needed for the grove gear. I also used stainless steel locknuts instead of the supplied castle nuts. Photo 3 shows hole locations for brake line attachments.
