With landing gear securely in place, I mounted the axles with 4 AN4 bolts and torqued them to 90 inch/pounds. Tthen I mounted both wheels and tires. Once the wheels were installed, the brake calipers were installed. I still need to find out from Grove the torque values are for rthe caliper pads. Once these are torqued, they will be safety wired.
