Put tube and tires together and installed wheel assembly and brake disc. Torqued wheel bolts to 90 in. lbs. Inflated to 50 lbs. Also showing picture of the landing gear brackets that are different from standard brackets since Grove gear is only 4.5" wide. Waiting on epoxy primer so I can prime landing gear as per manufacturer instrructions.
