Continued work on center console. The side pieces did not fit to my satisfaction so I had to fabricate some small pieces to rill space above center spar. Used plumb bob to determine location of L angles on floor. Drilled all parts and will take apart so I can add the nutplates for the side panels. I am making an assumption that this is the correct thing to do. The plans just show "screws". Not really sure what that means but I will ask Roger when I order the nutplates. Still some time left so I will work on nose gear for awhile.
