This evening I worked on more wire routing. I added some clips for the center wire run. (See pictures) After figuring out the route, I used the double stick tape on the tie wrap holder to hold in in place. Then, I put a pop rivet through the holders to keep them in place.
Again, I spent more time trying to figure out where to route the wire... than I did actually routing them.
I also drilled another hole in the ribs for the wire route from the wings to the center of the fuselage.
