This evening, I worked more on the wire routing. When installed the conduit in the wings, I had left two strings in each to pull the wires through. Pulling the wires should have been simple but I ran into a couple of problems. First, the wires kept coming unhooked. On the right wing, the wires I'm pulling get hung up on the wires for the autopilot servo. (I think the string I had in the conduit was wrapped in the servo wire.)
On the left wing, the pitot and angle of attack tubing kept the wires from pulling through cleanly.
