I continued work on the panel assembly and a few goofy items.
Misc. - riveted the F732 onto the roll bar channel (After priming) - fabricated a new baggage tunnel cover (Keeping up with my building everything twice routine:-) - fabricated the 788 gusset (I should have probably done it before the canopy frame. But, if you notice the canopy frame drawings... they say nothing about it... and it is not shown in any of the drawings 39-40)
Panel It looked like a pretty easy task. Just attach the 697 channel to the middle section of the panel. AGH! It turned out to be frustrating. The instructions are rather vague. I fabricated the 697. Then went to attach it. It is also attached in conjuction with the 643 channel. So, everything has to fit together just right.
I decided to put the entire panel assembly BACK together so I could make sure I had the channel at the correct height. I clamped everything in place... then decided to Google how other builders handled the assembly.
