- Drilled and clecoed both fuselage channels (644) - Fabricated, fitted, and drilled the engine control bracket and support - Installed platenuts for the panel and the engine control bracket - Clecoed the panel parts in place, drilled, and deburred all - Primed oodles of parts (Had a chance to try out my new painting mask. It actually works, I don't get a cheap high anymore. I don't even smell the paint. Cool...)
We are in the middle of a heat wave. The temperature in the hangar shot up to 50 degrees. (Although the floor is still about 5 degrees)
