After sliding the wing into the fuselage, the bolts come next. Cory was inside the fuselage and used a mirror to get the holes lined up perfect. I was at the tip of the wing moving it up, down, forward, and back as Cory instructed. Cormac had to get under the root and pushed up with his back. (It took ALL THREE OF US to get the bolts aligned.) When the first bolt hole was ready, Corey pushed in the temporary bolt. He ended up putting in three temporary bolts before installing the close tolerance final bolts.
