-checked tailwheel steering cable run for proper alignment-ensured nylon fairleads were bonded with resin and were inline with cables-rudder set in neutral position, steering cables tightened as per manual instructions and clamped-nicopress fittings swaged on each cable-rudder moved through entire range to ensure freedom of movement and check tailwheel travel
