-remove tail wheel assembly and springs -drill out #10 hole up through rear block and clean resin out of countersink-install fastener as per instructions-lubricate spring attachment bolt and install springs-install tail wheel assembly as per drawing (lubricate AN8 bolt with aviation grease to prevent wear
