Chuck S. Sportsman 2 +2 Site
Date:  9-12-2006
Number of Hours:  5.50
Brief Description:  Fuse Step 7 -9
Drilled pilot holes in the bases of all the fittings. Used the jig to find the positions for these holes.The excess portions need to be removed from all the fittings. Marked out the positions and removed portions as required by step 9, figure 7. The cut edges were deburred with the use of the grinding wheel and a file. All the edges were radius.
