Brief Description: Control stick pivots installation.
Modified R/H control column mount to allow installation of R/H control stick pivot. Then reamed several holes up to size for installations. Installed control stick pivots into control column with hardware called out in Figure B-4. Including installation of bearings. Also installed four socket head cap screws used for control stops. Had to tap holes for cap screws to remove powdercoating.
