Installed R/H control column mounting bracket to control column with hardware shown in figure B7. Then positioned control column in fuselage. Drilled up, deburred, and fastened R/H control column mounting bracket. Next I honed out L/H mounting bracket to fit control column. Drilled up remaining hole in L/H mounting block and installed L/H mounting block as shown in figure B-7.
