Brief Description: Elevator bellcrank installation.
Pressed bearings into idler bellcrank using liquid bearing lock. Then reamed mount tabs for bellcrank to .1875". Installed bellcrank in aircraft as shown in figure B-9. Assembled connect tube with rod ends and check nuts. Then installed connect tube in fuselage.
