Bill & Brendas RV-8 QB
Date:  8-2-2014
Number of Hours:  4.00
Brief Description:  Finish plate nuts in wing tips. Start lens covers
I ordered and recieved my 40 plate nuts to be used to finish the other half of the installation.
Same procedures followed as before but went a bit faster this round. Now as seen in pic one, its a bunch of plate nuts! Photo two shows the counter sunk rivits holding plate nuts in place as well as the countersunk screw hole which accomodates the dimpled wing skin.
Photo 3 shows the planned reflective backing for the position/strobe light. Used 0.020 aluminum I had and bent to 110 degrees on my handy metal brake from harbor freight. I held in place and traced the cut out edge which I will start tomorrow.
Not pictured is the start of the lens fitting for the position lights. I first cut the supplied one piece plexii in half and then ut off the lip around the bottom. I now have two over sized plexi covers that will need to be trimmed down slowwly to fit. Fun!
Wall to wall plate nuts. 38 in each wing tip
wing tip plate nut installation close up
Aluminum backing for wing tip lights.
