Brief Description: Adjust left exhaust brackets until the fuel line t
The photo below shows the bracket lower rt corner with 2 washers inbetwen the mating surfaces of the bracket as well as 5/16 spacer between the outside edge of bracket and the suport arm. This gave me enough clearence ( after some movement of bracket and lengthening the arms slightly) with the flex fuel line. You can see the fuel line center top of pictrure. It doesnt look like alot of clearence but it measures to 5/16 inch. Best I can muster. This should be fine unless Im told otherwise during inspection. But it looks ok to me.
