Brief Description: Aileron/elevator trim servo wiring
I connected d-sub pins to the three 24 awg wires from each of the trim servos. the 2 remaining white wires on each bundle are for power and will connect to the relays. I had purchased some 3 wire twisted 22AWg wire from stein and I ran it from the aprox location of where the trim servo led indicators are to be located and then down the left tower and then back to where I will position the relay module beside the aileron trim servo on the floor. Both servo wire bundles will meet up here and so will my indicator light wires.. So finished the dsub crimp on the wires from light indicators, assembled with shrink tube and covered all with one bigger shrink tube. Wire bundles were labled and tied back. Now I just need to attach the 2 white wires from each bundle to the realay and secure the bundles neatly. I glued the relay and the terminal block to the floor with amazing goop. I will probably secure with a single screw on each once Im sure they are not going to be moved. The terminal block is on oposite side just right of the center control tube.
