Brief Description: Connectorized the manifold pressure sensor
Located and stripped of 3/16" of insulator from the 3 wires for the manifold pressure sensor. Connected the pins with weather proof plugs and then plugged into the sensor body as indicated in the manual. Wires will need to be pulled up and secured later with other that get done. Note: One of the wires attached is a 5V excitation wire that is used for other sensors too. It will be spliced into several times before im done with it. Same goes for the ground wire attached to it.
