Bill & Brendas RV-8 QB
Date:  5-21-2011
Number of Hours:  1.50
Manual Reference:  6-12
Brief Description:  Rod end bearings
Fabricated a rod end bearing wrench out of short section of 1"dia. PVC pipe. Used this to screw in the 2 rodend bearings on each elevator spar to 13/13"
Set up table to provide enough room for the horizontal stabilizer and elevators.
Since the elevator tips wont fit until some skin is cleared away for clearence, I had to attach the elevators in a deflected position. Only inserted the bolts to hold in alingment. This will alow me to mark the skin for cutting the clearence needed.
My handy dandy rod end bearing wrench
Elevators temp attached to HS
